Sad seeing these old pictures. Reminds me back when you could just ride in any field, unload at any abandonded road and nobody gave a chit.
Still can in Idaho.
Still can in Idaho.
I have a friend that lives in Boise that said thats changing fast. He lived in Kaspell and its already like this in parts of Montana apparantly. Especially Kalispell area. SucksStill can in Idaho.
I live in Twin Falls, All the used to be gret riding areas...Closed up..NO pass signs all over.yeah well Boise is getting big so it happens. Got a buddy in Twin Falls and it's pretty lawless there :>)
'the beater'
'77 AW400 w/ 440 top end. solid alloy bars. Lectron carb. home-made pipe, roost-boot from PVC pipe and plumbing parts. custom air box for the high-pipe. MS dez tank. motoplat ignition. fox shocks. pic'd here anealing a head gasket on the camp stove. king of ugly bike. pretty fast too. ate honda's for lunch.
manly? ever pull the clutch lever on one of these? itll make popeye cry. plus the kicker snapped off first kick every ride (note lack of same) even with a comp release so i gave up and just push started it everywhere. also- had to be manly to wear these shorts in public.
hahaha another "right-side start" maico. i installed my comp release to try and stave the snappge. all it did was make it easier to push start hahaha. and after i dumped that breaker ingition it'd fire right up first kick. i started kicking it with the kill button on and with the lectron and the motoplat it'd fire right up and stopped snapping knuckles. i like the yellow bike you still have it? that'd make a nice project not many left. i may still have parts sources for a lot of goodies for those.
and thanks to the board for not making fun of my Magnum PI shorts....cuz im not in the mood fer slappin suckers today...![]()
I still think Levis were very good ride pants.
This 73 440 couldn't keep a kick starter either. The splines would usually strip first, then after welding the shaft would snap off, but the possibility of a broken case couldn't be ruled out either.
I'm pretty sure the same arrangement was used for 125-501cc.
Riding very far from the pickup was always an adventure.
I had a 70 250 though which was much more reliable and rode it many many miles from the truck, just had to be sure to bring enough spark plugs.
I miss my Maico.
Good eye Ray, Bing concentric they were called, and yes a tickler. The Bing concentric was actually a good carb compared to the remote bowl Bing it replaced.I think I recognize that tickler... Isn't that is a Bing CARB on this Maico?
You gotta go 3rd world if you want lawlessness ...
That is a 1973 125 Maico. It had a custom seat foam and cover, hand rolled up pipe, hand built aluminum airbox and the Koni shocks moved up on both the swingarm and the frame. The rotary valve was cut, and a modified Can Am piston was fitted to do the vroom vroom chores. It still had the boat anchor, steel channeled Radielli rims on it though.OK DD, are you going to withhold details until I slip off the edge of my chair?125?
