Same problem here. Fires but struggles a bit at a low idle. Using the enriched partially open helps. Otherwise runs great. May try the leaner G/B setting as well.Ok I'll try it out. I'm pretty sure I've tried it at all the way down to 1 or even the fast blinking 1 (when you go from 2 to 1 the hit the down/-/neg button the green light on 1 blinks faster than normal). That was done before adjusting the idle mixture screw though. I adjusted it to 5/6 when it starred to bog then toned it down til it felt and sounded fine and idled steady. I don't think it's a big deal using the lever every start even when hot, just figured I could tune it to not use it anymore only during really cold starts. Other than that the intense nose dive from letting off the throttle is gone and the choppy-ness at low gear n low speeds are gone as well. Still fine tuning things but overall really happy with it.
Take the maze out of the airbox! and the settings should be close.
Is taking the maze out really easy? I haven't tried even locating my airbox yet, I always make myself believe that since I have no idea what I'm doing, I shouldn't mess with anything. However, taking the maze out seems like something even I could do. Guess I just need to figure out what it looks like and how to get at it.
Download the 630 service manual here. https://docs.google.com/open?id=0B87JGKEoBQdza3R1N19wVV92YWM
Just bear in mind that not all jurisdictions have the maze (e.g. Australia doesn't). I couldn't tell from your profile where you are located.Is taking the maze out really easy?
