APT SmartCarb
Discussion in 'EFI/carb' started by Eaglefreek, Oct 22, 2012.
  1. Motosportz CH Sponsor
    Yep. I have three carbs.
  2. Toro618 Husqvarna
    wr125
  3. Motosportz CH Sponsor
  4. Toro618 Husqvarna
    wr125
    Ok thanks
  5. john01 Husqvarna
    Powhatan VA
    The 36 is the size I got and sent to Kelly that he has tested on his 125 and will soon be testing on his 165. They were out of 38's and I couldn't/wouldn't wait so I went with the 36. I can't even remember what they said would be different in terms of power delivery between the 36 and 38's.
  6. Toro618 Husqvarna
    wr125
    Do you know if it's the tapered design or not?
  7. Motosportz CH Sponsor
    It for sure is.
  8. Toro618 Husqvarna
    wr125
    Thank you.
  9. john01 Husqvarna
    Powhatan VA
    Kelly mine is the 36 straight.
  10. Motosportz CH Sponsor
    you have one too :D
    I will take a picture but the bore is for sure smaller on the bottom than the top. Looks like a taper bore to me.
    Toro618 - It is number 0000004 so you could call them and ask.
  11. john01 Husqvarna
    Powhatan VA
    Yep Kelly I just checked and I have (HAD :D) the 36 straight; cost was $775.00 ($787.00 after shipping). The taper bore carbs are $875.00. They all have the funny shape to them; kinda light bulb shaped and not round.
  12. Motosportz CH Sponsor
    OK, that is what I am seeing. I would call this a taper bore but whatever. thanks.
  13. john01 Husqvarna
    Powhatan VA
    LOL I don't know what to call it but it sure works :D. I asked them about the taper bore carbs and they were out of them too so I didn't even ask what the difference would be. They did feel the 36 was a good match for the 125-300 for the type of riding I do.
  14. MotoMarc36 Husqvarna
    wisconsin
    2012 CR144, 04 TC450, 04 TC250, CR50
    Many. Too many.
    The taper-bore will probably be 38mm on the machined-bore on the airbell side, and taper down to a 36mm nominal bore after the slide. The straight would be 36mm on both sides of the slide. The shape of the venturi, with it smaller at the bottom of the slide, maximizes low-speed intake velocity without sacraficing top-end flow. It would help explain the awesome response and low-end gains, no doubt.
  15. Vinduro Husqvarna
    Mississippi
    All over. I am from the South. I live in Mississippi and ride the Southern Enduro Riders Asso. Events (My Wife, Debbie is SERA President) and I ride a lot of Nat'l Enduros still.
  16. Vinduro Husqvarna
    Mississippi
    Kelly can contact me and borrow it. I won't be riding for 3 months. Shoulder Surgery next week (HemiArthroplasty). Kelly, Pay shipping both ways and you can borrow it for a week or two. I got a call today saying the Lectron is sitting at the shop that I keep my Vintage bikes at and buy most of my stuff from other than from Hall's Cycles and Motosportz.
  17. Vinduro Husqvarna
    Mississippi
    I want you to test on your 165 for a direct comparison.
  18. Vinduro Husqvarna
    Mississippi
    I would use the 36mm. A Lectron 38mm flows like a 40mm Mikuni.
  19. Vinduro Husqvarna
    Mississippi
    The Taper bore or as Lectron calls them High Veocity Carb is actually mainly for racing that restricts sizes of carbs so a smaller bore will flow like a larger carb. Lectron recommends staying to smooth bore for most applications.
  20. Blakelpd5 Husqvarna
    Tigard, OR
    09 WRWB165
    I just got a text from him a bit ago, saying the 165 is installed.... I'm burried at work, so I doubt I'll get to try it this weekend.. :cry:
    On the other hand, I'm making money :thumbsup:
    wallybean likes this.
