MikeB
Another race next weekend - kind of GP style with some MX track and 8 mile loops. The Husky has been teaching me how to ride and I've learned that I can carry more speed thru many turns by not slowing down as much then pitching the bike in ... before I get to the turn. The Husky searches for traction and take a moment to settle in and finally starts turning when I get to the turn and I'm then I'm on the gas early powering out. More speed in and more speed out.
I've put the stock 50 tooth rear sprocket back on and kept the 2 link longer chain which has shoved the rear axle all the way back. This puts more weight on the front tire which helps make sliding and turning predictable without having to climb all the way up on the tank (I'm 6' and haven't found handlebar clamps to put the handlebars far enough forward to make getting up on the tank easy), This also keeps the rear Pirelli trials type tire from getting too much traction too soon which is a problem I've been having. The 90 series Pirelli front MXMH has slowed the steering just a notch which I like. 7psi back and 8psi front.
When I shoved the axle back I had to reset the sag and put one more click of compression in the forks and the bike is really well balanced now.
) Donnie told me that the new KYB's are awfully good to start with so he only suggested the Merge springs for off road use to give a little softer initial feel.
