Just to clarify, there is only map 1&2. There are 3 sets of map 1&2. Set 1 comes installed from the factory and is very lean due to emission standards. Set two is a richer version of set 1. Set 3 is the maps I have been loading. These maps are tuned for racing exhausts with racing headers. They also work great with stock exhausts.
You know that shiny 449 of yours would look good with a shiny breather vent and bottle...Anything else I am forgetting?
Thanks in advance
Scotty
One of he guys mentioned R&D updated his ecu when he had his SMR last serviced, give Stefan a call and see what he says. Then let us know what he says![]()
You can just use a piece of copper wire or thermostat wire for the jumper, it is nothing special.If I load Race Map 3 into the ECU, do I need to install the jumper into the wiring harness? My new 2013 didn't come with the jumper and I would like to ride it this weekend with the good map.
Just called Stefan at R&D here in Sydney and I will need to speak to his mechanic next week about it. He seemed to believe that loading the #3 maps onto a 2011 TE449 ECU was a big problem / impossible as opposed to a 2012/13 model ECU?? Tinken - Can you shed any light on this or had any similar experience so far? If it's a drama here in Australia and you can do it no problem I'll have to ship my ECU Stateside to you.
Interesting, who told you that?Tinken,
I was told that map3 would not install on the ECU on my 2011 SMR511, and that it would only work on TE and TCs. Do you know if that is true?
