Well... you have to solder across E11 and E15 and dial back the Rms voltage until you reach 0.031 volts...
haha, just kidding. no soldering. I can do it no problem.
Tinken,
I was told that map3 would not install on the ECU on my 2011 SMR511, and that it would only work on TE and TCs. Do you know if that is true?
They're all the same except for the TC's efi system.
Tinken,
fast. Buddy with a TE310 said he thought the EFI is perfect now (it is) and is on a mission to make his 310 half as good.
I have a 2013 TE511 with the same occasional flame out and slight popping issue. I saw the BMW #3 map on Zip-Ty racing. Is that with the FMF slip on the easiest fix or should it include the JD tuner? Also would the FMF header help? It would eliminate the O2 sensor and looks cool!!, sorry, had to add it.
I think you should get the FMF slip on, there are other full exhaust systems out there, but that one is easy. At this point, the JD is really unnecessary. Map set #3 is more than just a fix for popping and flame outs. It's a brand new fuel map curve and is going to change the entire power delivery to your 449/511. You will see gains off the bottom and afterburners on the top.I have a 2013 TE511 with the same occasional flame out and slight popping issue. I saw the BMW #3 map on Zip-Ty racing. Is that with the FMF slip on the easiest fix or should it include the JD tuner? Also would the FMF header help? It would eliminate the O2 sensor and looks cool!!, sorry, had to add it.
Tinken can a 2011 TE310 be remapped and if so will the results be similar? He already got the FMF powerbomb from you but has not installed it yet.
Scotty, warp speed please.
Had me for just a second. That is crazy funny. I will find out Tuesday if my dealer can do the Map 3. If not I am mailing it in. I like the switch idea. Did you say you get better MPG with the non race mode? I am thinking about the nomad tank. I would really like 120 plus range. Today I got 37 MPG not enough for my needs.Well... you have to solder across E11 and E15 and dial back the Rms voltage until you reach 0.031 volts...
Tinken, how do I get a switch to go between the 2 mapsRace map set #3 really makes the TE and TXC's run the way they were intended to regardless of the exhaust you have mounted. Even better than the TC's imo. If you run map#1 with the new set, the O2 sensor still functions with better mpg's, map 2 is full race. I have a handlebar switch that toggles between the two.
Other items might include key switch, bags or you might want to look into purchasing some double take mirrors if you intend to mix mirrors with trail riding.
got a real dirt ride in, Gnarly single track with big loose climbs, blown out single track, hard stuff. The ECU remap made this stuff so much EZer. The glitch free flame out proof bottom end was super welcome. The big power though needed to be respected or things got scary quick. Smother and much more controlled off the bottom, way more mid and top end power. the thing is seriously FAST now. Likefast. Buddy with a TE310 said he thought the EFI is perfect now (it is) and is on a mission to make his 310 half as good.
The big boy showing the little guys that a big 4 stroke when setup right can git-r-dune. It felt like a magic carpet ride with a rocket strapped to it. Thought I would really miss my 165 on this ride but was not missing it at all. Scotty, warp speed please.
You cut the shunt loop on your power up plug and splice in a switch. I have one on my handlebars.Tinken, how do I get a switch to go between the 2 maps
Thanks for the info. I took it out to my local motocross track and in stock form it was motocross worthy. Can't wait to set it up the suspension and get the map and exhaust.I think you should get the FMF slip on, there are other full exhaust systems out there, but that one is easy. At this point, the JD is really unnecessary. Map set #3 is more than just a fix for popping and flame outs. It's a brand new fuel map curve and is going to change the entire power delivery to your 449/511. You will see gains off the bottom and afterburners on the top.
"Scotty, warp speed please."; "I'm given her all she's got Captain!"; "All's she's got isn't good enough, what else you got?!?" - StarTrek2009
If you want to see the kind of gains you are experiencing, then he is going to need PCV, especially with that megabomb to tune it. You can download our factory race maps from our forums. One of those Factory 4.1's wouldn't hurt either.
Thanks, I was skeptical about the remap stuff (ignorant really) until Whittier Honda remapped my CRF450R after I put a Yoshimura exhaust on. Smother, better and more power all through the power band. I'm a believer but still ignorant.For sure let ZipTy remap the ECU. Inexpensive and huge gains and how it runs and power.
That is a darn nice 98 KX there!!!
